Heat proof Glass
  • TropicalCoasting
    • Dec 2011
    • 408
    Heat proof Glass
    I have some old glass panels from an old 1970s gas heater
    They are roughly 200mm x 70mm wide and about 7mm thick. (brand new still in paper, have been bought as a replacement and never got used)
    something like this but older
    Need a new look for your house? Find 50 local house renovation contractors near you. Get FREE quotes in minutes from reviewed, rated & trusted house renovation contractor near me on Airtasker.
    As you could imagine having natural gas heating up the ceramic only centimetres behind it for years its a pretty heat resistant glass.
    Do you think this could be successfully incorporated into a dome to either create a window or protect a light?
  • Lburou
    • Dec 2010
    • 1165
    Re: Heat proof Glass
    jcg31 used glass for his blast door. That is the only place I'd consider glass in a wood fired oven, (because of the high heat loss via the glass).
    Lee B.
    DFW area, Texas, USA
    • TropicalCoasting
      • Dec 2011
      • 408
      Maybe it might be a good insert in a door, double or triple glazed???
      • GianniFocaccia
        • Jun 2009
        • 1645
        I have seen a build that incorporated a light-protecting window made of glass from a home oven. I know that this type of glass doesn't last forever, but is a viable short-term solution.
        • TropicalCoasting
          • Dec 2011
          • 408
          Do you have any photos?
          I think I've got 6 or 8 pieces buried away in the shed
          • Neil2
            • Oct 2006
            • 1374
            Apart from the heat loss thru the glass, it seems like a lot of trouble. I would imagine the glass sooting up fairly quickly as well.
            • GianniFocaccia
              • Jun 2009
              • 1645
              I think I saw the link to the actual build site was somewhere here on the FB site. If I can find it I'll post it. Sorry to not be of better help.
              John
