Using Limestone for oven floor
  • jeemann99
    • Apr 2012
    • 11
    My friend has a granite shop and has a piece of Grayish Limestone he had left over from a countertop 1 1/4" thickness and 4ftx4ft. I can have him cut to specs, but want to know if using this as the surface and using insulating firebricks underneath would be good enough without issues. Do I need to treat the limestone in any way?
    thanks in adance
  • Tscarborough
    • Oct 2009
    • 3341
    Re: Using Limestone for oven floor
    You need to not use it for the floor of your oven.
    • SCChris
      • Jun 2009
      • 1213
      The crystal structure of limestone isn't stable under the heat that WFOs get into. You'll be fighting it falling apart in short order.
      Sorry.
      Chris
      • SCChris
        • Jun 2009
        • 1213
        Originally posted by wotavidone
        On the other hand, supply it with a nice solid supporting frame, perhaps seal it with something, and I imagine it would be a lovely prep surface.
        Oh yeh!
        Chris
        • jeemann99
          • Apr 2012
          • 11
          what about soapstone I can get that too in 1 1/4" thickness. Will that work well as a cooking surface ontop of my insulating bricks
          • Lburou
            • Dec 2010
            • 1165
            Limestone, wherever you incoorporate it, is going to wear easily and produce a powdery surface with use....unless it has turned to dolomitic limestone, which is a bit harder.
            Lee B.
            DFW area, Texas, USA
            • jeemann99
              • Apr 2012
              • 11
              What about Soap stone I can ge that too
              • Lburou
                • Dec 2010
                • 1165
                While soapstone does absorb and hold heat well, the reviews are mixed on soapstone on the oven floor. Here is a good informational link on the subject. Keep searching, your friend will have something you need
                Lee B.
                • johnn34
                  • Jun 2012
                  • 1
                  Yes, you can give any shape to limestone tiles because these are flexible. You can use limestone tiles on flooring, countertops and walls.
