Cooking surface
  • Retodd87
    • 2
    Cooking surface
    Could you use 3" of Castable refractory cement for the cooking surface.
    • 9216
    Re: Cooking surface
    Large pieces of castable refractory are likely to crack. You could cast it into a number of pieces and reinforce them with stainless steel needles to avoid this. The castable refractory is really designed to be fired up to a high temperature where it will become partly vitrified and therefore stronger. If only taken to pizza temperature it will never be as hard as a firebrick which is fired to over 1000 C.
