Re: Soapstone Oven Floor
Soapstone is a poor choice for an oven floor. My reasons are here:
http://www.fornobravo.com/forum/8/so...tml#post128810
The talc lends conductivity to soapstone, making it more thermally durable. I don't recommend soapstone, for the reasons stated above, but, if you were intent on incorporating it, talc is an advantage, not a defect.
Also, the odds are probably in your favor, but it's not the best idea to bake on a cracked hearth. The thermal forces that generate cracks don't always create clean breaks and can weaken other areas that my not be visible. This increases the chances of shards breaking off and getting into food. Soapstone is one of the softer stones, but it's not softer than teeth.
I think that just about sums up the main disadvantages. Soapstone is great if you are made of money but most builders on this forum are looking to save a little coin. I put soapstone in the entry of my oven, which cost about $75 cut to size. I did that mostly for aesthetics.
FWIW Firebrick floors use about 30 bricks, not 60-80, if it matters.Leave a comment:
This is the soapstone we use. If you can find nice black soapstone you are pretty good. We have used green like this several times. It costs $7-900 for it all cut to our template. We use three pieces. It goes in super easy, but can crack over time. We never take it out so the cracks don't move or cause mush issue. Besides. Two cracks are far better IMO than the joints between 60-80 fire bricks. The thing to avoid is the talc, or white veins in the slab if you can. Good luck.1 PhotoLeave a comment:
Hey Rob,
Don't know the advantages/disadvantages of soapstone firsthand (my oven isn't operating yet) but here's what I've read/seen:
1. Soapstone can withstand oven temps but not forever. I have seen some of the thinner SS floors with cracks in them. This is why I placed the dome outside the floor
2. SS in larger pieces (I have three slabs) leaves fewer edges and opportunities to catch a peel
3. Dark SS will not reflect as much light as a lighter-colored firebrick, making the oven appear darker inside
4. SS is expensive unless you got a hook-up
5. SS conducts heat (both heat-up and cool-down) faster than firebrick. For this reason, it has been reported that SS is less-than-desirable for baking bread, but I think there are workarounds for this
6. A number of commercial ovens use soapstone because it recharges quickly
I plan to cook a number of dishes in pans using the soapstone floor as a heating 'element' with a fire going like I saw at the First Annual FB Expo. That plus pita breads with dinner
JohnLeave a comment:
Just finished my hearth and starting to study details of building the oven. Looked at photos of an oven building workshop and in the photos they used larger pieces of soapstone for the floor of the oven instead of firebricks. Seems like fewer pieces could create fewer edges for catching tools in the oven.
Anyone know if there are any advantages or disadvantages to using soapstone as a substitute for firebricks in the oven floor?Tags: None
