Soapstone Oven Floor
  • windage
    Re: Soapstone Oven Floor
    http://www.fornobravo.com/forum/37/8...t-11354-2.html
    link to the second page of my "81 inch first build" thread on FB, 10 slabs; 1000mm long x 300mm wide x 60mm thick from M. Teixeira were $59 each plus trucking from NJ...I have been baking pizza on soapstone for 4 years now commercially, we show no mercy to that hearth and it is awesome. You can listen to the negative people who have not used soapstone in their busy WFOs...but if you can swing the money....GET SOME, it is nice to bake on, makes beautiful crust predictably and the large slabs with a layer of firebrick below gives no cold spots. love it !
  • stonecutter
    The cost is one reason soapstone isn't used more. Additionally, it is much more conductive of heat than firebrick, which will make it more difficult to manage the bottom of the pizza or bread so it doesn't burn.
    Harder soapstone will contain more serpentine...and John was wise to select slabs that did not contain a lot of veining, which is the weak point of any kind of stone.
  • Greenman
    I know nothing about the properties of Soap Stone but it looks good and if it delivers then it has to be a good thing.
    I am sure that someone will come up with the facts that there will be a good reason that this attractive material is not widely used.
  • GianniFocaccia
    I have seen soapstone that I could break with my hands and soapstone that was almost as hard as granite and been in use as a counter for a 100 years
    Your soapstone may be on the softer side.
    I was fortunate to find soapstone that is virtually clear (no veins) and seems to be hard as steel. I cannot dent it, but I managed to put scratches in it from the circular wet saw I used to initially cut it. After several dozen pizzas no scratches from my metal peel so far (knock on wood).
  • nsascher
    My soapstone that I just purchased scratches very easily. Is anyone else having this issue ?
    nathalie
  • Stevenb
    No. Sorry. Pizza parlor wasn't mine. Trimwerks LLC and Brick Pizza Ovens on fb are mine.
  • Laurentius
    Originally posted by Stevenb
    Try Trimwerks LLC. It and brick pizza ovens are my pages on Facebook. If you come to town I can give you my phone number and let you look at a couple.
    Thanks Steven,
    I try Twimwerks, so, that pizza parlor wasn't your? I live in Japan, don't thinking I'll be seeing your ovens, up close and personal.
  • Stevenb
    David, we have had great use with almost no wear in three years. Not even any really noticeable scratches. We always try to choose what is considered "cooking grade" soapstone, and luckily that is what most suppliers up here get.
  • Stevenb
    Originally posted by Laurentius
    Hi Steven,
    I'm on FB and there's hundreds of Brick pizza oven, since I know that your location is Spokane, I came up with Brick City Pizza, is that you? Its a pizza parlor, where can I see example of your oven?
  • Tscarborough
    David, "soapstone" is a broad term covering a wide range of variation. I have seen soapstone that I could break with my hands and soapstone that was almost as hard as granite and been in use as a counter for a 100 years. You have to specify what the use will be for your soapstone.
    I've not had experience cooking on soapstone so can't offer any opinion in that matter, but i have had a lot of experience in sculpting it. Soapstone is the softest stone you can get and that is its attraction as a sculpting medium apart from its inherent beauty. It is way softer than firebrick, you can cut it with a hand saw, sand or rasp it easily. The resultant powder that it produces is talc powder, dust a little under your arms. Another name for the stuff is talc stone. Look up Talc Alf, an interesting sculptor who carves soapstone. My question is how does is stand up to the continual abrasion of metal peels, pokers and logs of wood abrading the surface as it's so soft?
  • brickie in oz
    Ok guys like it or not but its firebricks versus soapstone at ten paces at sundown, be there.
    Draw..........
  • Laurentius
    Hi Steven,
  • Stevenb
    Facebook if you have it. Brick pizza ovens.
  • Laurentius
    Hi Steven,
    Where can I see an example of your oven?
