what grade of vermiculite
  • anderstim
    • Oct 2012
    • 2
    What is the grade of vermiculite that is best for insulating around/above the dome
  • azatty
    • Sep 2010
    • 239
    Re: what grade of vermiculite
    Coarse to medium. You're trying to create air space within the material to trap the heat, so powdery stuff isn't preferred.
      • 9216
      Yes that's true, you don't want powdery, but the fine vermiculite makes a more workable mix although it takes more water. I doubt whether ther is any measurable difference between fine med or coarse in the final product, after all a bucket of small marbles weighs the same as a bucket of large marbles. The spaces maybe bigger but the volume of the spaces is the same. Try 50% perlite 50% vermiculite it makes a good workable mix with minimal cement needed to hold it together
      • azatty
        • Sep 2010
        • 239
        I figured you are using it for enclosure filling. But if you're doing an igloo, I'd go with david's suggestion.
          • 9216
          Yeah,sorry, I was assuming you we're doing an igloo. If doing an enclosure go with azatty's advice. Probably less compaction with the coarse stuff.
          • adypearson
            • Nov 2012
            • 2
            I am also search for the grade required for making an insulated hearth, but I can only seem to get my hands on Perlite ore down in New Zealnd.
