What is the grade of vermiculite that is best for insulating around/above the dome
what grade of vermiculite
Re: what grade of vermiculite
Yes that's true, you don't want powdery, but the fine vermiculite makes a more workable mix although it takes more water. I doubt whether ther is any measurable difference between fine med or coarse in the final product, after all a bucket of small marbles weighs the same as a bucket of large marbles. The spaces maybe bigger but the volume of the spaces is the same. Try 50% perlite 50% vermiculite it makes a good workable mix with minimal cement needed to hold it togetherKindled with zeal and fired with passion.Comment
Yeah,sorry, I was assuming you we're doing an igloo. If doing an enclosure go with azatty's advice. Probably less compaction with the coarse stuff.Kindled with zeal and fired with passion.Comment
I am also search for the grade required for making an insulated hearth, but I can only seem to get my hands on Perlite ore down in New Zealnd.Comment
