Re: Home brew concrete and cast-in-place concrete.
I "Googled" (Xypex) and came across a report on a project "Tsuen Wan Station Project" --an evaluation of this product.
It is really an amazing product from what I briefly read. Forms a crystaline structure that fills voids in concrete to prevent water penetration.. And the crystaline structure continues to grow with age. Properties that remain equalling the service life of the concrete. That is my short version of a 17 page report.
Also, it stated that it could be applied to the outside of a surface- presumably as a liquid form (or) in some type of mortar to give waterproofing qualities. But a better scenerio would be to use it when the concrete is being mixed--instead of a surface treatment- the entire casting would be waterproofed!
Simply amazing.
I would assume that this product would be popular and available here. It would be used in highway and rail (tunnel) construction where water is an issue causing degradation of reinforcement etc. Japan has a huge infrastructure of tunnels in its transportation network, both above and below sea level! I guess searching for it might not be so difficult--That is "if you know the right question to ask"...(Abreviated "Laurentius quote")
Another great piece of information to file in the back of your mind. If a situation arises where you are building an oven or (in fact anything) from concrete- that is subject to running water, or contact with high concentrations of water--that could be problematic...there is a product available to solve the problem--and a name for it!
Simply amazing.
