Originally posted by Tscarborough
View Post
Re: My Brick Selection ok?
But i would be building a hearty so easy do insulated one and would be putting least 2-3in loose vermaculite around full oven
Cutting i have large and small geunders with diamond blades and also have lian consaw
Issue is i have enough tapered brick fir barrel style not a donr oven sadly
That means buy time buy materials it go wat over budget
There is pizza oven kit locally
Wood Fired Pizza Oven Kits
They don't have insulation under the hearth and little if any on the dome. The firebrick will take a long time to heat up, conversely they will hold that heat for a long time. The frogged brick should work OK, but the frog is going to be an issue. How do you plan on cutting them to use?
cheers will go find him on here soOriginally posted by UtahBeehiver View PostMaybe contact AMAC on the WFO forum, he is from Ireland and just finished his build last year. Maybe he can give you better info on what is available in your neck of the woods.
do you mind if i ask what these are so i dont make same mistake?Originally posted by mrchipster View PostAll of the ovens on the site you linked have serious design issues. I would rethink them as a viable option.
Chip
i do see an aful lot of cement between joints and large door ope
All of the ovens on the site you linked have serious design issues. I would rethink them as a viable option.Originally posted by john_aero View Postwell white bricks are very heavy so i will be using them for arch.
i will have look into the red bricks now sure they will work
half tempted get one these
Italian Pizza Ovens Online store directly from manufacturer,
Chip
Those "free" bricks will work fine in many part of your build with the exception of the hearth floor (due to the taper direction), they may be super duty, similar to what I used in my build. If they are super duty (high alumina content) they are a little tough on saw blades. Can't comment of the others though.1 Photo
Ok managed to get time start the build again.
just have pour the slab for oven and then build.
I have the following bircks already and want see if they will suit?
i got the red bricks for 50 euor and tapered furnace bricks for free.
i have 120 red brick and 55 fire bricks.
the fire bricks are left overes from a furnace re lining job in my last job and are very heavy bricks. just want see if they are ok to use
the red bricks came from old fire place and are the old handmade tyre brick. the only issue i have is the have a hollow section.
I plan use arched bricks for my tunnel donw, the red bricks for 3 block high side wall before the arch and on their face for the floor.1 PhotoTags: None
