Local HomeDepot has this mortar.
TXI 70 lb. Type N Masonry Portland-Lime Blend Cement-9991 at The Home Depot
MSDS : http://www.homedepot.com/catalog/pdf...4d0f879a03.pdf
Can I use it as a base? If I'm reading right it is about 1-1 Lime, Portland.
So adding 3 parts sand, 1 part clay will make reasonable home brew mix?
