Does anyone know where to get fire clay in Massachusetts? I am on the north shore. Heat stop is $62/bag.
Looking for fire clay in Massachusetts
Re: Looking for fire clay in Massachusetts
Builders fire clay and potters fire clay are different. For builders the fire clay is simply used to make their mortar more workable. For potters their fireclay is used to increase the refractory properties of a clay body to be fired to very high temperatures. We only fire to around a max of 500 C so you only need the builders fire clay, (or IMO any powdered clay).Originally posted by Nosyapa View PostFound some at Portland Pottery in Braintree $36 w/tax for 100 lbs.
The builders fire clay, or sometimes called bricklayers clay, will be way cheaper too, available from building supplies.Kindled with zeal and fired with passion.
Thanks for the information. Other than price is there an issue? I only found one masonry place close to me that had fireclay and it was actually more expensive, but only had one bag. Many places had no idea what I was talking about. The stuff I got they say is used for cob ovens so I think I am ok?
Easiest place to get it is from the tray of your brick saw. Once you start cutting bricks, you will be throwing it away by the bucket load.
Golly gee I threw out lots of it, and did not even think twice. But I only paid $15 for my nice clean sifted dry bag from my supplier Smith Sharpe in Minneapolis Mn.Originally posted by deejayoh View PostEasiest place to get it is from the tray of your brick saw. Once you start cutting bricks, you will be throwing it away by the bucket load.
If I knew I could repackage it I could pay for those diamond blades I used on my saw.
Chip
I hear you there chip I have a tray full of brick shavings. I don't plan to use them though as I like the very fine sifted stuff I got from smith sharpie. But if someone in Mn wants it they can have it. I wish you could pay for the blades with the stuff as mine is pretty much shot and I need to get another blade.
Randy
