hello all i cant seem to find 9 in fire brick anywhere from newark to newton nj only 8 1/4 any suggestions ?
fire brick
Re: fire brick
i just called clayton and they werent able to tell me whether it was medium or low duty. it was 8 1/4 as well. www.claytonco.com they are located in Wall.
does the size really matter for you? cutting principles should remain the same. -
Re: fire brick
if i wanted to keep the thickness at 4 1/2 i would have a lot of waste . and I'm not sure if i used a half brick if the loss of half a inch will matter as far as retaining heat. then i thought to use the cut end facing the side but forno bravo directions say cut end faces out. so i have no ideaComment
Re: fire brick
I built my dome with 8 1/4" brick cut in half. I don't have anything to compare it to personally. But, it retains heat very well. (That may also be attributed to good insulation) If you really want the extra thickness, cladding is cheap
Joe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
Re: fire brick
im gettting ready to start my build, so i dont know for sure either, but i dont think the half inch on either side will affect anything. Clayton also told me that they buy their bricks from Whitacre Greer, and according to their website specs, the bricks they have will be ok for use.Comment
Re: fire brick
I wouldn't even worry about trying to add 3/8" cladding. That is plenty of mass to work with using half bricks (the actual thickness will be 4", 8.25" minus the 1/4" the saw removes).Comment
Re: fire brick
A bunch of us, including Les, left the cut side to the interior. I beveled and tapered each of my dome bricks, which ended up less than 4" wide facing inwards. Whatever size you have will work fine. If its bread you're baking, like Gulf said, cladding is cheap.Comment
