Flu Liner
  • JACK
    • Jan 2009
    • 22
    Flu Liner
    I have read somewhere that normal clay flu liners won't stand up to the heat from a Pompeii oven. So my question is do I need a special clay liner or just the normal like the ones used in fire places?
    • 9208
    They just need to be insulated. If uninsulated they will crack.
    • JACK
      • Jan 2009
      • 22
      Thanks David.
      If the flu liner is insulated that will make it get even hotter. Maybe the insulation makes it heat evenly, and prevents it from cracking.
      Thanks again
      Jack
      • fox
        • Mar 2017
        • 388
        I have used insulated stainless steel on the ones I have built, I then use a clay chimney pot to cover the stainless.
        • JACK
          • Jan 2009
          • 22
          That's beautiful fox.
            • 9208
            Originally posted by JACK
            Thanks David.
            Thanks again
            Jack
            Yes that’s correct. It is the difference between the temperature on the outside and the temperature on the inside that sets up a difference in thermal expansion that causes the cracking. The insulation reduces this difference enough to eliminate cracking. The clay itself is quite refractory and has been fired to around double the temperature that you will give it..
            • JACK
              • Jan 2009
              • 22
              Thanks Davids, now I understand and can move forward. I sure don't want to do the liner twice.
              • JACK
                • Jan 2009
                • 22
                While on the subject of insulating the liner, I assume loose fill perlite would be OK for that.
                  • 9208
                  Yes. Other options areperlcrete, vermicrete or blanket.
                  • JACK
                    • Jan 2009
                    • 22
                    Thanks david s
