I have read somewhere that normal clay flu liners won't stand up to the heat from a Pompeii oven. So my question is do I need a special clay liner or just the normal like the ones used in fire places?
Flu Liner
Yes that’s correct. It is the difference between the temperature on the outside and the temperature on the inside that sets up a difference in thermal expansion that causes the cracking. The insulation reduces this difference enough to eliminate cracking. The clay itself is quite refractory and has been fired to around double the temperature that you will give it..
Kindled with zeal and fired with passion.Comment
