Finding Materials?
  • Finding Materials?
    I have been doing a bunch of reading and have decided to use the homebrew mix (3:1:1:1 sand, portland, lime, fireclay) to make the refractory layer in a cast oven. I cannot find hydrated lime locally. would if be safe to use this product as the portland and lime for this recipe?
    https://www.homedepot.com/p/Quikrete...2570/100318484
    Thanks in advance.
    John
    If it's 50:50 Portland cement and lime, which it looks like it is, then yeah it'll be fine. You'll just want to do 3:2:1 Sand:mortar mix:fireclay.
      The homebrew mix is really more for sticking firebricks together with though. I don't think the consistency would be right for using in place of firebricks. I'm sure there's a different mix for refractory concrete but I don't know what that is.
        Yes there is a different mix designed for the purpose. It’s called castable refractory and relies on calcium aluminate cement rather than Portland. It is expensive. Using the home brew as a castable does work, probably not quite as good as the proprietary castable refractory, but is really cheap.
          Thanks in advance.
          John
          No, those premixed products usually contain lime in the form of crushed limestone (not suitable). If you can’t get hydrated lime you may be able to find hydraulic lime which is another suitable alternative.
            hello, for the first layer of the dome what is the best material? Stucco?
