Where can I find vermiculite in the US?? The only thing I find is garden stuff.
ah... thanks for clarifying, Ricky, regarding the silicone coating and the water repellency. Maybe that is why it's more difficult to mix with concrete than vermiculite?
there is also non coated perlite. It is used in lightweight concrete but the cement content in that is much higher than you would be using.
Hello Bethencourt. I've been keeping a file I call "oven notes" which includes info I've found that may be helpful for me in my build. I saw your post and had the following in my notes. for what it's worth, and I would do your own research, but this is info I had gathered regarding vermiculite vs perlite:
Caution. Perlite can be coated with silicone to make it slide easily into block cores, where it's commonly used as an insulator. Make sure you locate plain, horticultural grade perlite, not the construction grade. The insulative properties are nearly identical.Use perilite as opposed to using vermiculite. Vermi is softer whereas perl is harder. Go with perlite and hard strength cement.
I'd like to hear what others may have to say as the info may..... or not .... be helpful.
Masonry Perlite is coated with silicon to make it more water repellent and has nothing to do with it to easily slide in the cores of cmu block. It won't wet with cement but It should work fine as Russell's experience suggested. The cement holds the perlite in place not the other way around so coated or not the cement will bind it together and will function as intended. This also isn't your finish coat and your render will lock this layer in futher.
Also, poolkrete will not work for you as it has way more cement in it and will not be a good insulator. Its just a softer cement product used for for the floor of inground pools that utilize a vinyl liner. Not what you are looking for.
I used commercial grade perlite for my dome pcrete and did not have any issues with the coated perlite. More important is using the correct consistency, not too dry, not too wet, not too thick at all at once.
Look at perlite then. I should be available at any masonry supply store. It is used to insulate Concrete Masonry Units (CMUs) by pouring in the cores. 5 to 1 ratio for floor insulation, 8-10 ratio for dome and interchangeable with vermiculite.
I'm not in the US and don't know if there is a difference, but try looking for chimney insulation as vermiculite is used between chimney liner and bricks.
Hi,
I've been trying to find Vermiculite but I can only find the garden one, not construction.
I'm almost ready to start the building. Planning to pick up the calcium silicate boards, Ceramic blanket, etc this Friday.
