Try two layers then. The cal sil available to me comes in 40mm panel thickness, so two layers is required. If cost is prohibitive you can try laying a layer of 5:1 vermicrete first, but give it at least a couple of weeks to dry, before laying the 30mm panel of cal sil over it.
Gravity will hold the two layers together. There is no need to glue them.If placing a second layer on top of the first, stagger the joins.
The second suggestion, which is a cheaper alternative is to lay a layer of vermicrete first, on top of which you can lay the calcium silicate board.
Vermicrete is a mix of vermiculite (or perlite) and cement, to which water is added forming a wet mix that can be laid to form an insulating layer. The proportion of cement determines how strong and how insulating the resulting layer becomes. The attached table explains the strength to insulating value relationship. The problem is that the water contained in the layer needs to dry out before building over it. Oven builders regard a 5:1 ratio is required to provide sufficient strength for a heavy oven to sit on.
