Is someone can help me with details how can I convert my wood pizza over to propane . The regulations in Canada does not allow wood anymore. Please help
Converting my Neapoli from wood to propane
What ever answers you may get here, please consider a certified gas burner install. Some of the hacks out there can be dangerous!Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build -
Plus one on Gulf's comment. FB sells a certified gas/propane burner unit called a Drago but it still should be installed by a certified plumber.👍 2Comment
👍 1Comment
Burning fallen timber is using carbon that is already in the system, just returning it to the atmosphere a little sooner than rotting or being broken down by insects and far better than using an electric oven powered from a coal or gas power station or burning the gas directly in the oven because this is using fossil fuels which add extra carbon to the systemKindled with zeal and fired with passion.👍 1Comment
