Converting my Neapoli from wood to propane
  • Davidsell
    • Jul 2023
    • 1
    Is someone can help me with details how can I convert my wood pizza over to propane . The regulations in Canada does not allow wood anymore. Please help
    • 3885
    What ever answers you may get here, please consider a certified gas burner install. Some of the hacks out there can be dangerous!
      • 5264
      Plus one on Gulf's comment. FB sells a certified gas/propane burner unit called a Drago but it still should be installed by a certified plumber.
      • Pizzarotic
        • Jan 2022
        • 133
        Another first for canada saving the planet
          • 9216
          Burning fallen timber is using carbon that is already in the system, just returning it to the atmosphere a little sooner than rotting or being broken down by insects and far better than using an electric oven powered from a coal or gas power station or burning the gas directly in the oven because this is using fossil fuels which add extra carbon to the system
          • Sdogg
            • Aug 2023
            • 5
            Hey I'm from Canada too
            I'm a bit in the dark about this regulation.
            Where can I find it?
            Is there a size limit to whether something is allowable to use wood firing or is it a full on prohibition?
