Neapolitan oven - lower dome height
  • olddude
    • Jul 2009
    • 61
    #31
    Re: Neapolitan oven - lower dome height
    seems to me it goes like this the lower dome cooks a (better) pizza
    because the top is closer to the pizza but the higher ovens reatin more heat from the wood using less wood also get hotter faster
    So i have sloved the problem well not me but someone did here it goes make a high dome oven
    cook pizza then lift pizza up for say a count of 5- 10 to char top note this is not allways needed but there if needed know you have a round oven with a high dome to hold the heat in from the fire longer. starts faster uses less wood.
      • 9213
      #32
      The lower dome reduces the chamber volume and hence the size of the fire which would result in a slower heat up. In practice I don't think it makes much difference, they all cook well.
      • shuboyje
        • May 2009
        • 406
        #33
        To me the big difference is a lower dome oven can be run hotter. The low dome will cook the top fast enough that you can keep your hearth temp up without burning. My oven has a 13" dome. I can run at a 1000F hearth temp and kick out 40 second pies all day long. If I bring the temp down below 900 the top can actually cook too fast. That heat and speed isn't critical for great pizza but for the style I like to make it works very well and gives awesome oven spring
        • Neil2
          • Oct 2006
          • 1374
          #34
          A hemisphere has a single focus point = the centre.
          An ellipse has two, or in 3 dimensions a ring.
          • Tscarborough
            • Oct 2009
            • 3341
            #35
            And a barrel vault, with coals and flame on one side, has a line the length of the oven.
