Re: Neapolitan oven - lower dome height
seems to me it goes like this the lower dome cooks a (better) pizza
because the top is closer to the pizza but the higher ovens reatin more heat from the wood using less wood also get hotter faster
So i have sloved the problem well not me but someone did here it goes make a high dome oven
cook pizza then lift pizza up for say a count of 5- 10 to char top note this is not allways needed but there if needed know you have a round oven with a high dome to hold the heat in from the fire longer. starts faster uses less wood.
