Barrel Style oven layout question
  • meco211
    • May 2010
    • 81
    I am working on the layout of the oven.. On the walls do you usually lay the firebrick tight together or space then and lay with refractory mortar? I have attached a picture of the dry layout that i have came up with, just curious on the spacing of the walls.
    Any input would be appreciative..thanks
    Toby
    Columbus, NE
  • meco211
    • May 2010
    • 81
    Re: Barrel Style oven layout question
    Well i think that i am going to put a small joint of mortar in between and on the bottom, think that it will keep the sides and top more even
    Toby
    Columbus, NE
    • Tscarborough
      • Oct 2009
      • 3341
      Is it a full barrel vault or a flattened one?
      • meco211
        • May 2010
        • 81
        well it will have a rounded arch...kinda like the one in Alan Scott's Book. Pretty much the same layout as he uses for the oven 36 deep by 32 wide and a 16" door
        Toby
        Columbus, NE
        • Archena
          • Apr 2007
          • 1214
          Um, why is the door on the end? I've never seen a barrel oven (brick) done that way.
          [/CENTER]
          • meco211
            • May 2010
            • 81
            Arch
            guess i am not understanding what you mean, the opening is in the front.
            Toby
            Columbus, NE
            • Archena
              • Apr 2007
              • 1214
              The ovens I've seen had the door along the long side.
              Forgive my lack of Sketch Up skills, but the picture probably explains it better.
              [/CENTER]
              • meco211
                • May 2010
                • 81
                I see what u are meaning now..Maybe too i am using the wrong terminaligy. i will kinda look like that except the door is in the front. Just oblonged shaped with arched roof
                Toby
                Columbus, NE
                • ThisOldGarageNJ
                  • 1436
                  Meco,,
                  Far as I've ever seen the door is in the front like yours,,, Looks like your off to a good start..
                  Cheers Mark
                  • meco211
                    • May 2010
                    • 81
                    That is a nice looking oven in the picture u posted!
                    Toby
                    Columbus, NE
                    • Tscarborough
                      • Oct 2009
                      • 3341
                      If it is a standard barrel arch, there is no need to soldier the first course.
                      • ThisOldGarageNJ
                        • 1436
                        Hey Meco,
                        Stand barrel arch or wheather you soldier the first course or not, (your choice)My point was just to show you that the entrance is commonly in the front... Its is a nice looking oven, Just a pic I found on the web...
                        Mark
                        • DrakeRemoray
                          • Mar 2006
                          • 1215
                          I see you have posted quite a bit so you probably already answered this, but why a barrel oven instead of a Pompeii?
                          My Oven Thread:
                          • meco211
                            • May 2010
                            • 81
                            Guess i just like the look of the barrel better! not knocking the other just my preference
                            Toby
                            Columbus, NE
                            • Tscarborough
                              • Oct 2009
                              • 3341
                              If you look at my link it shows all stages of a housed barrel oven being built.
