oven position
  • sumu
    • Oct 2008
    • 100
    oven position
    does it matter if the oven opening faces prevaling wind or not.
  • Billz
    • May 2010
    • 7
    Re: oven position
    Quick answer would be yes. as per the plans under tips and hints
    "When selecting the direction your oven will face, consider
    making sure that your opening does not face possible
    winds, which might disrupt your cooking and fire
    management."
    • sumu
      • Oct 2008
      • 100
      Re: oven position
      thanks so if the wind is from the west mainly point opening north .
      • fxpose
        • Jul 2009
        • 942
        Re: oven position
        But in many cases you want your oven facing in a certain direction for aesthetics and for practical reasons. So if you have a constant wind problem you may need to balance those elements and reach a compromise.
        George
        George
        My 34" WFO build
        • sumu
          • Oct 2008
          • 100
          Re: oven position
          gottcha thank you
          • Neil2
            • Oct 2006
            • 1374
            Re: oven position
            You could build a section of fence to screen the oven area if the winds become a problem.
