Starting on my cast entry arch and vent. Here is a pic of the foam form I'll use to build the full form around. Quick job with a 1 1/2" 4'x8' sheet of foam board from Home Depot. Snowed today...next week is supposed to be above freezing. Hopefully get some work done outside next week.
How best to heat water using excess heat from oven
Terratree, below are three posts where I have discussed IT designs - at least the way I understand how they work. The first is from my build. There are quite a few designs that get your axis of rotation and pivot point at the center of the oven - you just need to be creative. I was inspired by Gulf's design, and cannibalized an old bike rack to get the piece I used for my IT centerpoint. Did you attach a pic of your IT - I didn't see it?
Also, I built my dome on top of my floor bricks, and had read somewhere of using news paper to keep the dome bricks from adhering to the floor - possibly allowing some float. Don't know if it was needed but as I said I was just following instructions.
Lastly, I had a couple different versions of the spread sheet, but between my ability to measure an angle and replicate it on my saw I found it easier to just make two cuts on scrap and see if the bricks fit together enough to eliminate the vertical vee.
I've been working on my oven for a little while and have been debating starting a build thread, as I probably won't have much to add in terms of artistry or inventiveness over the excellent work already posted on this forum. That said, I thought I would share what I have done and hopefully continue to get
My indispensible tool (a variation on a FB theme) - Forno Bravo Forum: The Wood-Fired Oven CommunityShare your favorite tools, time saving tips, and what you learned while building your oven.
Hi All, I want to start a thread to document the design process of my oven as it evolves and to benefit from the input of all the experienced builders on this site. Please feel free to raise any points i may be overlooking as i plan. Thanks in advance. Here are the plans of my design so far: 1. It will beMy build thread
I built a canopy under which I dry firewood. It consists of 3 walls and a roof. I thought that one open side is enough, because I will not climb into the very middle of a pile of firewood, but I will take those that I hide. If the weather is wet, then cover the open side with a tarp. It took me a long time to make such a small building for firewood, but while there were warm dry days in winter, I tried out my new cordless tools and assembled this shed literally in a day. Of course, I ordered the wood earlier, it was in my garage so as not to damp it in winter. Now, hopefully, I will always have good dry wood for the stove or for the barbecue.
