Hi Guys,
I'm doing my intitial research for a WFO (pompeii, probably ~42"), and for a few reasons (rental house, semi-perm installation), I would like to build it on a steel tube frame stand (like Toyota8's mobile one). I have decided to put it on castors or somehow concrete it into place.
So I have two questions:
(1) what size steel is needed to support the oven's weight? I would probably go with a similar design to Toyota8's with 6 legs (more if necessary). I was looking at 25mmx25mmx1.6 (1"x1"x1/16" - if my conversion is correct), but I don't know if that is large enough...it's a considerable price increase to 50mmx50mm, but would do it if needed.
(2) is there an easy way to install it into individual concrete 'pads', rather than making a giant slab? Can the tube just be sunk into the concrete, or does it need to be mounted on top of the concrete?
I hope I have made some sense
Cheers,
Ross
Cheers,
Ross
