Hello all, My oven is basically finished with a good cured mortar layer over my insulation. I will likely be tiling with a mosaic or slate. Ive cured the oven properly and used it several times and all has gone well. Here's my question is the mortar porous enough where rain would soak back in and cause re introduction of moisture? Ive got it covered but with big winds its questionable and is still getting some rain.There is a a sealing product my mason recommended but i hesitate to do anything until the weather clears? Thx for any advice
Rain and my unfinished oven
Re: Rain and my unfinished oven
Once you've done the initial cure you shouldn't need to go back to do the whole curing process again, but after heavy rain it's a good idea to do a drying fire the day before you want to cook. If it has moisture in it then more of the energy put in is used to convert the water to steam, resulting in a slower temp build up.Kindled with zeal and fired with passion.
