Adding a smoker
  • Adding a smoker
    I was asked today if anyone had installed, or thought of installing a
    smoker next to their brick oven. The idea was to re-direct the smoke
    exhaust into a separate chamber for "cool" smoking for fish, etc.
    Has any done, or thought about doing this?
    Thanks for the input.
    Re: Adding a smoker
    My initial research was to build a brick smoker for briskets and ribs and that's when I came across brick ovens. I'm planning on starting this fall once our Texas heat dies down and I like the pompeii approach versus the casket approach but still researching to see how this oven would do on a brisket. I found this website that shows their construction of both. I haven't called them yet but I'm still wondering if I need both.
    hillcountryoutdoorkitchens.com/smoker.htm
    RCLake
    "It's time to go Vertical"
    Oven Thread
      Re: Adding a smoker
      Do a forum search. I remember someone mentioning usiung the oven as a smoker and it working quite well.
      I plan on experimenting with that since you can trap the smoke with a door and the residual heat storage a brick oven gives would make it great for holding temp. I am too lazy to do like my brother in law, get up very easrly, then tend the smoker on/off all day. Much better to place it in, leave for 8 + hrs and come back when it is done.
      Wade Lively
        Re: Adding a smoker
        Here's a thread on it:
        I plan on torturing many a brisket in this manner....
        "You better cut the pizza in four pieces because I'm not hungry enough to eat six."
        -- Yogi Berra
        Forno Tito
