Refractory over a barrel mold
  • buckeyebreadman
    • Mar 2011
    • 156
    Simple question:
    Anything wrong with using a 55 gal. plastic drum cut in half and form Refractory Cement over that? Obviously the door would have to be molded separately, and it should be molded in pieces, (to account for expansion later without cracking the whole thing).
    Total Newbie here just doin' my research.
  • buckeyebreadman
    • Mar 2011
    • 156
    Re: Refractory over a barrel mold
    also.......premixed or homemade cladding?
      I don't normally answer refractory castable questions, but I think there might be an issue with shrinkage, using a rigid form. I'd ask your castable suppler about forms.
      • buckeyebreadman
        • Mar 2011
        • 156
        My primary concern is: Is it a viable option?
        I plan to cast it in pieces to negate the possibility of cracking. Shrinkage, I'm not worried about as this will BE the oven (portable, used only maybe three times a month)
        any advice is greatly appreciated.
          • 9211
          If you make up the castable using the correct amount of water, the shrinkage is negligable because the aggregate used in proprietary mixes is clay which has already been fired, therefore no shrinkage of wet clay particles. If you cast over the plastic drum you will need to cut the drum out in pieces from the inside. This may be more difficult than you envisage. How thick do you intend the castable refractory layer to be? I do not understand your Q. re cladding, can you elaborate?
          • buckeyebreadman
            • Mar 2011
            • 156
            Thanks for the reply David....
            I plan to cast over the drum, then turn it over and remove the drum mold. THEN place the cast on a firebrick hearth and cover it all with unsulating blanket/vermiculite etc.
            I can't see any difference in my project and a purchased pre-molded oven.
            I do have a severe shortage of ca$h and have always been one to innovate rather than pay retail....just tryin' to cut costs.
            again, I'm only using this oven down at the campground...I'm also building a Scott oven at my home by the book.....
            • brickie in oz
              • 3445
              Same here..
              One of the faults with his ovens is the fact that the dome is not bonded, you must bond to achieve maximum strength otherwise the dome could delaminate along the join lines.
              • buckeyebreadman
                • Mar 2011
                • 156
                You lost me there Brickie.....forgive my ignorance but what do you mean by "bond"?....
                • brickie in oz
                  • 3445
                  My dome above is bonded, that is that the bricks on the next course are lapping half of the brick on the previous course, etc etc.
                  • buckeyebreadman
                    • Mar 2011
                    • 156
                    Actually, I thought about that when I first started looking into building an oven......I'll certainly do that when I build the Scott oven.
