Questions for a new build
  • azpizzanut
    • Aug 2010
    • 397
    #16
    Re: Questions for a new build
    The "cladding" closest to the dome is Kaolite refractory insulation, 2" thick. I applied it a handfull at a time packing it in good all around. Several bags came with the kit. The outer is perlite/Portland cement at 5:1 ratio. I used a gauge with a center-pin to measure the thickness of the perlite mix as I went along.
    Cheers,
    Bob
    • Neil2
      • Oct 2006
      • 1374
      #17
      "I also didn't have to edge trowel "
      It is always a good idea to edge trowel any slab. If you don't, the initial slight curing shrinkage will leave you with a slight "dish" edge which may end up being a water trap.
      • Cdubs
        • Feb 2011
        • 66
        #18
        can someone explain what "edge trowel" means and how I go about doing it?
        My Oven Thread:
        http://www.fornobravo.com/forum/f6/c...ild-15677.html
        Picasa Photo Library:
        https://picasaweb.google.com/1020617...72/WFOProject#
        • azpizzanut
          • Aug 2010
          • 397
          #19
          Hi Neil2,
          Yes, you're right. A slight dish will appear at the edge of the slab from shrinkage, and sure enough, it does catch a little water. However, my slab is fully enclosed and tiled at the front, none of it is exposed to rain. Edging it was just exercise.
          For those builders that place concrete for structural or decorative elements of their ovens or outdoor kitchens edge troweling is a must if it will be exposed. Newbies might be tempted to begin working the cement before it is ready, and if it is started a little bit too late, then it is difficult to work the stones down and retain a smooth edge. When done at the right time the finished product is a thing of beauty, very satisfying. It gives a very "finished" look to the job. An oven sized slab is easy, a patio or driveway is a lot more work if done on hands and knees though. Get the right tool for the job and you'll be a pro in no time at all.
          Cdubs, Neil2 posted a picture of an edge trowel, above. They also come with wooden handles and are not expensive. I've had mine for years. Clean it up and take care of it when you're done and it will always be ready when you are. Same as for any tool.
          Cheers,
          Bob
          • Neil2
            • Oct 2006
            • 1374
            #20
            I suggest using the edge trowel right after pouring and floating / leveling the concrete. Use lightly, just enough to "push" the larger aggregate particles in away from the edge.
            Use it again lightly after about 1/2 hour and once more when doing the final finishing after skim over.
            Its actually even easier than it sounds and gives your work a nice "professional" touch. They are relatively small tools, about 6 inches long and 3 inches wide and will run $7 to $10, and as Bob says, if cleaned and put away will last forever.
            If you live in an urban area, take a look at the sidewalk in front of your house. An edge trowel was almost certainly used and that is what produces the rolled edge and border effect.
