Curved Brick Cuts
  • Jethro
    • May 2011
    • 11
    Curved Brick Cuts
    Sorry if this question is answered elsewhere; however, I've searched the forums to no avail. Here's my question.
    When laying the oven floor inside of the dome, the floor cuts appear to be actual curves. What type of brick saw can make curved cuts like that? Many posts say they are using a Harbor Freight saw but I don't see how curve cuts are possible with this tool. What am I missing?
  • tusr18a
    • Mar 2010
    • 95
    Re: Curved Brick Cuts
    The curve is made from several straight cuts. Draw the curve on the brick. Start making straight cuts with a wet saw to remove the part of the brick on the outside of the curve. Labor intensive. However, that is how it is often done. Remember you can also build the dome on top of the hearth. By doing that, you do not need to make the curved cuts.
    • RTflorida
      • Jan 2007
      • 1446
      Use the above method to remove the majority then simply "nibble" with the wet saw. You will be amazed at how precise you can actually make curves with a bit of practice. Literally within the width of a hair. practice, practice, practice
      RT
      • Lburou
        • Dec 2010
        • 1165
        Welcome Jethro
        We set the first chain of bricks on top of the oven floor -You don't need anything but one straight cut to do that.
        Lee B.
        DFW area, Texas, USA
        • Jethro
          • May 2011
          • 11
          Ok - Thanks to all who responded for the help. Kinda what I figured but wanted to make sure.
