kit vs built?
  • jodyj
    • Jun 2011
    • 1
    kit vs built?
    We live in SW Va (near Roanoke) and want to put in a pizza/bread oven. So far we haven't found a mason who's done this. We found one who used a kit.
    Could the person who built the footer and box and flue for our fireplace build a pizza oven or is the learning curve too steep?
    What is the cost difference between making your own and using a kit? Is there an advantage other than cost on either method?
    There are so many considerations, it's a confusing.
    Thanks!
  • ptone
    • Jul 2010
    • 21
    Re: kit vs built?
    If you are not into building it yourself, I would go with a kit - with your oversight a mason should have no problem putting one together - but read the directions and communicate with them regularly.
    -P
    • Neil2
      • Oct 2006
      • 1374
      Re: kit vs built?
      "Is there an advantage other than cost on either method?"
      Either will provide a good oven.
      The kit method is faster but more expensive. The brick build is often the choice for the do-it-yourself type who enjoys building and learning new skills.
      • Faith In Virginia
        • Oct 2010
        • 713
        Re: kit vs built?
        I am also in SW Virgina. Check out your private messages. Be sure to check out the section on my WFO.
        I would think that if your not a do it yourself person and needed to hire a mason I would guess the price would work out the same.
