Thermocouple Queries
Re: Thermocouple Queries
RF
One in top of dome, one about half way up the dome and one in the floor. The two dome ones are approx center of each brick. I built mine with dome on top of the floor, so the side of the floor was exposed. So, I drilled a 9 inch long hole sideways into the floor for the floor TC. I forgot to mention that I got a 12" for the floor one. Once the dome brickwork was done I drilled and placed the TC's, then used a small amount of Heatstop to try and seal the hole around them. I then covered my dome with about 2" of perlcrete. Then layered the blankets, punching a small hole where appropriate for the connector of the tc to fit thru. So you can see the tc's extending out past the blanket. Then I was just going to put a square of foil around the tc to reflect any penetrating heat, but decided to lay an entire layer over the dome, just loosly placed. Then cover my dome with loose perlite (harborlight). If you look closely at my oven posting you can see the tc's sticking up. I did not see any reason for a hearth TC.
I also bought Omega's infrared gun and will be plotting core vs face temps on my next firing.Wade LivelyComment
