split stand - wood storage both sides
  • larrycooper
    • Jun 2011
    • 42
    Anyone ever put row of block across center of stand and use angle iron on both front and back - giving you access to wood storage from both sides so you don't need to crawl into stand to get wood from rear? I would think adding a row of block across center would give you greater structural support even though the use of angle iron on both front and back seems to be less strong???
  • wesslock
    • Jun 2008
    • 36
    Re: split stand - wood storage both sides
    I would have changed the base for easy access as well. I thought a plus sign with the left half of each side as a wall. So you have half of each side open with angle irons holding up the other side. You would have four shallow wood storage areas. I know its not a popular but it would actually look like a swastika from the top.
    It is very hard to reach the wood in the back of the storage area so I wind up not using it.
    • Ken524
      • May 2007
      • 1655
      Larry,
      There are a couple of folks on here that have done exactly as you describe. I don't see any problem with it. Wish I would have thought of it!
      Ken H. - Kentucky
      42" Pompeii
        • 9211
        A wood storage open both ends also has the advantage of allowing air fow through keeping your wood drier.
        • Tscarborough
          • Oct 2009
          • 3341
          I did an "H" shape, but closed off the back. My wood storage area is, in fact, a completely separate brick box built under the oven. I only wanted it big enough for a fire or 2 because of bugs and critters.
          The guts of the stand:
          (I did not pour a concrete slab, I used 36x36x3 slabs cut to fit)
          • larrycooper
            • Jun 2011
            • 42
            done, thanks for the input. I'm going to put some wings on the side so I'm not sure if I'm going to have additional wood storage or maybe a outdoor fridge or maybe a kegerator with tap.
