Re: Starting new 36" build
Very Beautifuldvm
sigpic
Russell -
thanks for asking about the foot. It is improving. I'm in a walking cast now, no more crutches. I am getting around much better now, but still looking to get out of this thing!
Been sniffing around the clearance sales for next year's board... thinking about that Burton Barracuda.
Carnuba + Beeswax treatment on outdoor concrete counters = what seems to be a very good idea
Counter with a full wax treatment
Counter with only a test area waxed
I was frustrated that the counters were so dull and dingy after the winter. Cleaned them up and tested a small patch... then a larger patch... and as soon as the rain clears up I will do the whole thing including the mosaic!
The first wax I used was a furniture polish called Feed-n-Wax that is not exactly food safe. But it worked so well that I bought some Butcher Block Conditioner by the same manufacturer to do the rest. Both have beeswax + carnuba wax as the active ingredients. The wax really brought back the shine to the counters, and you can see how it repels water. I think I will probably need to get into a routine of applying every few months in order to keep up the appearance of the counters as the weather is too hard on them to go with no maintenance.2 Photos
I'm a Burton fan from way back. I still have my Woodie 145. You must be a free rider powder hound if you like the Barracuda. I have both a Vapor and a T6 depending on what the snow conditions are. But the T6 is my fav. very stable and around. The Vapor is a little noodlily. Have not been able to ride much this year, had to go on sabatical from teaching at Snowbird due to an aging parent. Next year. Glad the foot is doing better. BTW sure like the mosiac, was at the Met in NYC last week looking at mosiacs and it reminded me of your oven. The 2013 oven builders are starting to surface and looking forward to see what new WFOs look like.
PS Feel lucky that your counters are just dull and dingy they could look like mine, spalling and damaged.
Beads up like no tomorrow, I have used a water based sealer on my granite counters,they are still shiny but do not bead water like that.
I have a cutoff I think I will try a wax treatment to see how it holds up. I can put thr cutoff in full sun and weather to give it a good workout.
Thanks for this update.
ChipChip
I got a little work in on the oven last week, finally getting through the lame foot and the crappy weather. At long last, I finished the brick work above the arch so I have the faux chimney in place. I think it came out pretty well. I got most of the trim under the eaves installed too.
Now I just need to get the brick onto the chimney chase and the saw goes onto craigslist
About to put in a couple loaves of Ciabatta this morning...1 Photo
I liked it so much I just sanded one of my peels and applied it to that. It also worked a treat on brightening up the colors in the mosaic.Originally posted by mrchipster View PostBeads up like no tomorrow, I have used a water based sealer on my granite counters,they are still shiny but do not bead water like that.
Chip
OK, I am almost there:
- Landing permanently installed: Check
- Eaves and trimwork installed: Check
- Eaves stained and trim painted (SO did this one): Check
- Brick trim that I knocked off while installing said trim reinstalled: Check
Last stuff to do:
- Point up bricks on chimney (will be referencing the internets to figure out how this is done)
- apply 3-layer stucco to oven house. I am starting scratch coat tomorrow
- Put all tools back in the garage, power wash everything, and finally just enjoy backyard!
The finish line is in sight.
I'll be interested to hear if power washing is sufficient, or if you also need acid and a scrub brush to clean up the patio.dvm
sigpic
very cool! Glad to hear you have survived the winter shut down and back at the wfo. I REALLY like that faux chimney of yours! I may have to add (steal) that.
TracyTexman Kitchen
More progress to report:
Got the chimney tuck pointed. That was much easier than I expected, and actually kind of fun! I just need to do a bit of cleanup with muriatic acid. I found a great video on Youtube that showed how to do this.
I am 1/3 of the way through the brown coat on my oven house. Again, it is not as bad as I feared. I am taking it a bit slow - going as far as I can with a bag of mortar each day. Masonry experts, please tell me if I am making any huge mistakes, but let the little ones slide
. I used s-type mortar for both the scratch and brown coats. Stuff that I picked up at HD that says "use for scratch and brown coats" on the bag. Hope this is right. Seems fine. I've applied about 1/4" for each coat. Takes about 1 + 1/2 bags to do a coat.
I do have questions about the final coat. What do I use there? Is there something with an additive that offers better water resistance? And what about pigment? Can I mix the color in instead of painting? Does that start with white mortar so I can do lighter colors? I haven't really research yet, so thought I'd just throw those out there.
Hoping I can finish up by Thursday, I am having a bunch of the neighbors over for dinner Saturday to see what I have been up to so I'd like to get all the tools out of there for that.4 Photos
Do a google for acrylic render.Originally posted by deejayoh View PostI do have questions about the final coat. What do I use there? Is there something with an additive that offers better water resistance? And what about pigment? Can I mix the color in instead of painting? Does that start with white mortar so I can do lighter colors? I haven't really research yet, so thought I'd just throw those out there.
It comes in a variety of colo(u)rs and is water proofishish.
The guys i hired for stucco used the cement based mortar for scratch coats and then used synthetic (acrylic) like brickie said. The builder supply place where i bought it said "nobody uses real stucco anymore for final coat." fwiw The stucco guy agreed and said the synthetic is better and lasts, and easier to apply.
It was an El Rey brand and you can pick the texture and color to your taste.
TracyTexman Kitchen
