Can I use inulated firebrick?
  • Eddie4
    • Jan 2008
    • 33
    Almost ready to set the oven floor.
    can I use insulated firebrick as the insulator between the oven floor and my cement slab? I did not insulate the slab, its just 6" of concrete.
    Thanks ,
    Ed
  • Laku
    • Jul 2010
    • 152
    Re: Can I use inulated firebrick?
    You can, but you need about 4" thickness of them if I remember correctly. The insulation value should be about the same as with vermi/perlcrete.
    • Johnny the oven man
      • Jun 2008
      • 399
      They will work fine.
