Pacific Clay Brick
  • RTflorida
    Re: Pacific Clay Brick
    It says they meet the ASTM standard for residential fireplace brick, thats good enough. Fireplace bricks work perfectly fine (speaking from experience). It would be nice if they had a slightly higher alumina content (mid 20s), but you won't know the difference.
    If they are readily available and inexpensive there is no reason not to use them.
    RT
  • Phxdt
    thanks. I have read all the threads related to the brick, but just wanted to be sure before I make the purchase. Kinda critical component, you know?
  • deejayoh
    That's what I think would be referred to as "low-duty" firebrick, which should work just fine for the floor and the dome. I think plenty of builders have used it.
  • Phxdt
    started a topic Pacific Clay Brick
    Pacific Clay Brick
    I received this letter from a brick manufacturer. Could I use this for either the floor or the dome?
    Please accept this Letter of Certification verifying that Pacific Clay Brick Products ?Fire Brick? (4-1/2? x 2-1/2? x 9? or 4-1/2? x 1-1/4? x 9?) will withstand temperatures of 2300  F. with an Alumina (Al203) content of 21% and a Silica (Si02) content of 70%.
    This brick is not refractory brick and will not meet the ASTM specification for refractory brick. Pacific Clay is in conformance with ASTM C 1261-10 (Standard Specification for Firebox Brick for Residential Fireplaces)
    Sincerely,
    Pacific Clay | Brick | Pavers | Bullnose
    (951) 674-2131 FAX (951) 674-6383
    14741 Lake St., Lake Elsinore, CA 92530
