Pacific Clay Brick
  • Phxdt
    • Apr 2012
    • 49
    Pacific Clay Brick
    I received this letter from a brick manufacturer. Could I use this for either the floor or the dome?
    Please accept this Letter of Certification verifying that Pacific Clay Brick Products ?Fire Brick? (4-1/2? x 2-1/2? x 9? or 4-1/2? x 1-1/4? x 9?) will withstand temperatures of 2300  F. with an Alumina (Al203) content of 21% and a Silica (Si02) content of 70%.
    This brick is not refractory brick and will not meet the ASTM specification for refractory brick. Pacific Clay is in conformance with ASTM C 1261-10 (Standard Specification for Firebox Brick for Residential Fireplaces)
    Sincerely,
    Pacific Clay | Brick | Pavers | Bullnose
    (951) 674-2131 FAX (951) 674-6383
    14741 Lake St., Lake Elsinore, CA 92530
  • deejayoh
    • Jul 2010
    • 1893
    Re: Pacific Clay Brick
    That's what I think would be referred to as "low-duty" firebrick, which should work just fine for the floor and the dome. I think plenty of builders have used it.
    • Phxdt
      • Apr 2012
      • 49
      thanks. I have read all the threads related to the brick, but just wanted to be sure before I make the purchase. Kinda critical component, you know?
      • RTflorida
        • Jan 2007
        • 1446
        It says they meet the ASTM standard for residential fireplace brick, thats good enough. Fireplace bricks work perfectly fine (speaking from experience). It would be nice if they had a slightly higher alumina content (mid 20s), but you won't know the difference.
        If they are readily available and inexpensive there is no reason not to use them.
        RT
