The standard build with the CMUs dry stack for the base look like a good way for a newbie mason to do the work, but if I really want to stretch this project out to be over the next dozen years or so, what does everyone think of using stone for the base walls?
I have access to field stone that I was considering using as the base wall materials. In everyone's experience what might be the pitfalls of this approach? Also, if I go with stone, do I lay it up as a wall by itself (stone only), or do I pour inside walls (inside the stand) at the same time as I pour the hearth pad, using the stones as a form on the outsides? Or maybe there is a another better approach...
It will be a little tricky forming the hearth pad with uneven edges on the base walls, but that will help stretch the project out...
So many choices! Thanks for your thoughts!
Carl
Carl
. Don't get me wrong. I am enjoying the build, but the fruits of this labor have to be "enjoyed" to make "the build " come full circle
