Re: Rustic Primitive Materials
Annie,
I really don't think that aluminum dryer vent pipe can withstand the heat from your oven, nor do I think that drain tiles are fired at a high enough temperature to keep them from thermal shock.
Gudday Annie
Sorry for any probs with this post I'm using an I phone as the powers off and on at the moment. Where just getting the tail end of a cyclone here that's been down the coast. No worries here were on the lee of a hill higher than any flood and protected from the wind.....anyway.
You said in a previous post that were sorry not to have set you pearlcrete layer in a brick edge. Sorry for the misunderstanding that "plan" was not a diffinitive thing it was a lot of achievable sort of goals ( I thought) because at the time you were stuck firmly in the petty details and was losing the end goal. a working oven. But as a definitive plan its not ,but more a base line you could change at will.
Well you've got that soft pearlcrete edge don't worry about it yet I'm sure it will stand up to the rigors of your building for now. Leave the finish till the end. You could cement it and cover it with another finish. You could brick it now and see what it suits at the end. Or perhaps leave it for now and finish it at the end. Tiles mosaic ? Brick? Lime render ? Polished stone from the beach?
The neighbors arrive to share the storm. They have power but no beer it seems....better break out the chips and dips
Regards Dave
Annie, My first post on your thread although I have read and followed for some time.
Good looking cat, is that a Maine Coon?
The edge of your insulating layer will be weaker but more important the edge will allow water to enter. The insulating layer will act as a sponge, a band or belt of concrete around the insulating slab would be better. A simple form would make the job easy (chasing members so you do not have to cut wood). Including a piece of rebar would be great and give the belt some resistance to cracking especially in the corners. Lacking rebar you could use barbed wire which might be more easily formed and available.
I would not suggest modifying an oar for a peel unless you have an extra oar from a broken pair. Easy enough to cut a small plank down. Here's a photo of what I mean:
Your location lists Pacific Northwest. I too live in the Pacific Northwest on the Olympic Peninsula (on the Puget Sound side just south of Port Townsend).
Bests,
Wiley
Annie,
I wouldn't worry about it or do the additional work, I think all is well.
Hi Annie,
If you mean, starting the oven wall outside of the perlcrete layer, that is the same as having no insulation! The heat from the oven will sink into the stone structure, its suggested that you expand your perlcrete, so that your walls are insulated. Excuse me if I misread your meaning.
I used lava rock. We call it scoria, it's the reddish brownish aerated rock. I found an academic paper that said a mix of 3 parts scoria as large aggregate, 2 parts sand and one part portland cement had enough insulating properties to properly qualify as an insulating concrete. I reckon the mix I used had a thermal conductivity of about 0.25 W m-1 K-1. The paper gives all the mix components by weight, I had a lash at working that back to volumes based on bulk densities, and decided 3 parts scoria, weighed a bit less than 2 parts sand, and I part cement weighed a bit more than 3 parts scoria and nearly as much as 2 parts sand, so I reckoned I'd end up with mix B1 in the attached paper.
Not as good as vermicrete, but way better than ordinary concrete.
That mix has an MPa of over 20. That is over 3000 PSI, well and truly strong enough for a slab to hold up an oven.
I stood my sailor course of bricks straight on this slab. I put a 2 inch layer of vermicrete inside the ring of bricks, then put my floor bricks on that.
So my floor bricks sit on 5 inches of insulation, my dome sits on 3 inches of insulation.
And yes, it is full of holes even after you mix it into concrete. The second photo some aggregate I took out of my cement mixer and broke open to see whether the sand and cement paste had clogged the pores of the volcanic rock. the answer is no.Attached Files2 PhotosLast edited by wotavidone; 01-25-2013, 07:25 AM.
We didn't get an answer on thisOriginally posted by Annie M.Just wondering though... has anyone ever used the lava rock under their oven? I have an offer of a few big bags of the small rock for free if I wish to use it... any experience/ideas about this?
Im assuming its got trapped air in it and it wont melt that it would work as insulation
Ann,
Been following your build from day one. Those oars might good bread peels. I think Tu made some long and narrow peels for bread. Here is a link to Tu's bread peels he made. Looks like the oars can work perfect.
My oven is also small (21") so I tried cooking bread on two levels, using a metal rack for a second level. It simply didn't work. The upper level bread shielded the bread on the bottom. Remember that a WFO works by radiating heat unlike a conventional convection oven. By all means give it a go, but I won't be surprised if you end up with the same disappointing results that I got. If you use a refractory shelf it might work better, but firing up with it in place may be problematic.Originally posted by Annie M.It will be a humble little 28" oven floor... enough for a nice pizza... but also I have an idea for a 'stone rack' so I can do different kinds of baking on 2 levels.
Be careful, the upper level will be hotter.
Hi Annie,
Looking good. What size oven will it be?
Happy New Year! So glad to hear that you are forging ahead. Yours is such a unique and all natural build, I look forward to seeing/hearing of your progress. I can't wait to see that gorgeous cast iron door on the front of your oven. I don't know how you plan to use it (it looks so heavy) but it looks just the thing for a "Rustic Primitive" oven.
Good Luck,
ATLast edited by ATK406; 01-15-2013, 08:41 PM.
Sounds like you got the consistency pretty close. If it had been a "pour" type of consistency the portland would have settled to the bottom. You might want to cover the slab for a few days to keep it from drying out to fast. That will give it some time to cure. If they are not in your way leave the forms in place as long as possible. A couple of weeks if they are in your way. I removed some bracing from mine after about a week. The actual form was left in place to protect the edges much longer.
In all of your pictures, it always looks wet. Is it?
