Re: Rustic Primitive Materials
Gudday Annie
The "home brew " mix has
Sand... The aggregate, the matrix ,all the other parts fill the spaces inbetween the grains
Portland cement ....the "glue " that sets first and holds the show together till the temps of your oven destroys it
Hydrated lime.....the higher temp "glue" that takes over from the Portland getting stronger in the heat
The clay..... Makes the mortar stick better to the brick, let's you squish the brick down if its to high. Slid the brick a bit when not perfect without it the mortar will come away from the brick. It's the part that allows " masonry inpaired" folk like myself to build a 1/2 reasonable oven.
By the way wash that beach sand to remove the salt it weakens mortar and concrete
Regards Dave
Gudday Annie
Regards Dave
