Re: Rocket pot oven
First things first, I appreciate all the feedback. And I can take a joke as well as the next guy. So no worries about my fragile ego- I can both diagnosis and treat myself, but don't tell anyone
And apologies to Wiley, it was Al who was cracking wise about my yard
Tscarborough - Really, double the temperature, does it really need to be 1000?? Actually I found it rather easy to double my temperature. I just put another thermometer in the oven and instantly I had two thermometers over 500?. There you have it 1000? plus. Actually I did Max out one thermometer at 600+. I'm hoping to get higher than that with improvements in my design. I hope you'll talk to me even if I don't get up over 1000?.
I think I'm going to go with as small of a door as possible. Since I don't need the 63% to burn, All I really need is a chimney on top to allow the rocket to vent.
I have already experimented with blocking the inlet on the rocket to help her Serpi. The floor does cool rather quickly however I think that is in part my lack of patience and not allowing it to get fully up to Temperature.
As far as pots go I actually had two stoves in the pictures the taller pot was removed in favor of the lower dome of the same circumference. I'm hoping this reflects more heat back on to the cooking surface.
I believe I will need insulation over the pot of some sort. I attempted to find insulation for a furnace but all I could find was fiberglass. I may have to go back to perlite or vermiculite and concrete.
I think this rocket stove idea all boils down to time versus mass versus efficiency and is a plausible idea however when it comes time for me to build a permanent woodfired up and I will end up going with the old tried-and-true.
David is your oven only 21 inches internally? do you find it difficult to have space for a fire and a pizza?
I shall make one more attempt to attach multiple pictures they should demonstrate the difference between the large pot the small.
Okay that didn't work I guess this will serve as a quick picture of my lower domed pot/oven
