Indoor oven venting
  • Jeff B
    • Jun 2009
    • 13
    Indoor oven venting
    Hello
    I am planning a home theater / game room / pub area in my daylight basement and would love to have a wood fired pizza oven so of course I have a few questions.
    Nearly all of the indoor pictures I have seen have what appears to be a vent hood of some kind above the oven opening. Is this for any smoke that may leak out during lighting? Is this tied to the flue or a separate fan/exhaust path?
    The top 18" of my basement walls are above ground so I was thinking of running the flue out the wall near the ceiling, then a T with cleanout outside then a vertical pipe outside. Has anyone done anything similar? Or any other ideas for a basement flue?
    I'm sure I'll have many more questions.
    Jeff
  • brickie in oz
    • 3445
    Re: Indoor oven venting
    Hi Jeff.
    I assume it would be separate as tying into a flue higher up would make the flue not draw properly.
    • REE REE B
      Hi Jeff
      I would check with your local building code inspector to see what you need for something like that? as with our indoor pizza ovens the require a double wall chimney and you can also get an elbow chimney pipe as well if you needed it.
      • shuboyje
        • May 2009
        • 406
        Burning solid fuel code will require a class A vent. This can be a manufactured system like REE REE B mentions or a custom welded system built to the proper specs which will include 3" of fire wrap.
        • Jeff B
          • Jun 2009
          • 13
          Originally posted by REE REE B
          Hi Jeff
          Are you talking about the duratech stainless pipe or the black double wall pipe?
          I have the outside chimney figured out, now it's just a matter of figuring out the inside pipe.
          I sent an email and called and left a message for the county so hopefully I hear back soon.
          • brickie in oz
            • 3445
            Youll need stainless as anything less will rot out in no time.
            • Jeff B
              • Jun 2009
              • 13
              Thanks, that's what I thought.
              • Jeff B
                • Jun 2009
                • 13
                Looks like I need a 90 degree elbow, but I can only find 30 degree elbows in stainless.
                • brickie in oz
                  • 3445
                  90 Degrees is bad for a chimney, 45 is good 30 is better, you just need more pieces.
                  • Jeff B
                    • Jun 2009
                    • 13
                    Has anyone used the Duravent DVL pipe? It's stainless on the inside and galvanized on the outside.
