Re: Before pulling the trigger, in need of criticism
Portland cement is calcium silicate. High temperature cement is calcium aluminate. If your product contains calcium silicate then it is probably very similar to vermicrete which is simply calcium silicate cement and vermiculite, although the brew you have probably contains other ingredients , probably fire clay and a stable aggregate of fired crushed clay and fibres. Calcium silicate is not suitable for the hot face.
I have not seen the photo of the oven you are describing, but many manufacturers (FB included) make entire ovens using castable refractories, but they all use calcium aluminate cements.
