36" build in Tallahassee - AKA Bruce's Folly
  • stonecutter
    • Jun 2007
    • 2003
    #361
    Re: 36" build in Tallahassee - AKA Bruce's Folly
    The numbers on my diagram are based on a guessimated height of your spring line. You really should measure to get the height...I'm not sure that the span and rise on my drawing will work with what you actually have.
    Old World Stone & Garden
    John Ruskin
    • Bec1208
      • Nov 2012
      • 416
      #362
      I planned to resize, wanting to leave a wider reveal. Was confused for a second, first thought reference to spring line was to outer arch (floor level) then realized you were referring to spring line of inner arch. Thanks again, Bruce
      Link to my build here:
      http://www.fornobravo.com/forum/f6/3...lly-19181.html
      Selected pictures of the build.
      https://picasaweb.google.com/1168565...g&noredirect=1
      sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
      • stonecutter
        • Jun 2007
        • 2003
        #363
        They are one in the same.
        Remember, if you enlarge the reveal, you create a higher rise...which will widen your span.
        John Ruskin
        • kanoer54
          • Apr 2013
          • 137
          #364
          bruce, i have been following your build with great interest. i am just starting my build in southern illinois and read your posts almost daily. you have raised lots of good questions i would never have thought of asking. i have learned a lot from you and all the others on this forum.
          it won't be long and you'll be cooking five-star restaurant meals in your oven non-stop. it will make the food on your trip out west (which i also followed with great jealousy) seem like run of the mill diner food.
          best of luck on your flue and entry.
          jon
          jon
          • Bec1208
            • Nov 2012
            • 416
            #365
            Good guesstimate, inner spring line is about 8 1/4". I cut 3 forms but haven't assembled them yet. They have a 14" rise and a 25 inch span. I did a mockup and the pic below is how it ended up. Does it look usable?
            • Bec1208
              • Nov 2012
              • 416
              #366
              jon
              Thanks for the comments. I read through your current thread, very interesting approach. Look forward to watching as you go along. Pay attention to stonecutter's instructions for designing an arch. Haven't mastered it but I wish I had learned these lessons before the working on the inner arch. Let me know if I can help. Good luck with the build. Bruce
                • 5260
                #367
                Bruce,
                No moss grows under you. When you decide to go it is 110%. On the home stretch. Great thread to watch.
                • Bec1208
                  • Nov 2012
                  • 416
                  #368
                  Just to give everyone a laugh, here are Mark 1 and Mark 2 versions of what may or may not resemble a "trammel".
                  • Bec1208
                    • Nov 2012
                    • 416
                    #369
                    Bruce,
                    Thanks Russell, I really got the urge to finish after completing the inner arch. It felt like things were downhill from there. Bruce
                    Here's looking at you.
                    • Bec1208
                      • Nov 2012
                      • 416
                      #370
                      Bruce,
                      Russell, I believe you used a duravent flue. I have an 8" adapter plate and need to work out smoke chamber and mounting the plate. Any thoughts on a simple layout (I recall yours as being fairly intricate)? Bruce
                      • stonecutter
                        • Jun 2007
                        • 2003
                        #371
                        Whatever works....it's the end result that matters most.
                        John Ruskin
                        • stonecutter
                          • Jun 2007
                          • 2003
                          #372
                          Yes, that looks usable... good job.
                          John Ruskin
                            • 5260
                            #373
                            I used Selkirk which is like duravent and the anchor plates are similar but not interchangeable. I did anchor the plate to the vent stack then capped my with bricks but I have seen several builds lately with just mounting the plate to the right to the vent stack. You might even consider a clay flue. The duravent or selkirt are really spendy. I am not sure how high you need to go but a clay flue is cheaper and if you do not need to go too high. Mark 1 or Mark 2, if it works, why not.
                            • Bec1208
                              • Nov 2012
                              • 416
                              #374
                              I want to keep options open, I picked up the adapter plate used for $22 including shipping. My thoughts at the moment are to set up the vent up to the plate. At that point get the dome insulation completed and either stucco or start curing the oven. I think to do this I need to switch from whole bricks to 1" slices to span the upper arch. I can see a couple ways to get through this, suggestions appreciated or I can learn from my own false starts.
                              • Bec1208
                                • Nov 2012
                                • 416
                                #375
                                Thanks, you really helped me through this. Currently looking at options to create vent to chimney transition. Hope to be able to work it out tomorrow. Bruce
