36" build in Tallahassee - AKA Bruce's Folly
  • Bec1208
    • Nov 2012
    • 416
    #526
    Re: 36" build in Tallahassee - AKA Bruce's Folly
    Gudday Bruce
    [ATTACH]38048[/ATTACH]
    Attachment is a firebrick brick which I have stained with some deck stain just to see if it would soak up a stain. Firebrick is "pretty ordinary" in colour but pretty porous and I was thinking perhaps the entrance could be coloured with some of that waterbased colour that you used in your stucco. This is just a seed of an idea at the moment.....is it colour fast? can it be sealed? I don't know its just an idea at this time.
    I have never heard of anything like this being tried before..... but perhaps an experiment on a couple of firebrick off cuts? your off on Hols (again) so some samples can be left to wheather to see what happens?
    Regards Dave
    Staining the firebrick is an interesting idea. Looks like the stain is taking in the pic you attached. If I pick up a stain to experiment with, any shade you would recommend? Bruce
    Link to my build here:
    http://www.fornobravo.com/forum/f6/3...lly-19181.html
    Selected pictures of the build.
    https://picasaweb.google.com/1168565...g&noredirect=1
    sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
      • 2848
      #527
      Gudday Bruce
      I was thinking of stuff you used to colour your stucco, its a liquid is it not? It would probably come exactly the same shade but near enough. One thing that might effect the final result could be any residue of mortar or lime might make the brick take up the stain unevenly. You might have to give the brick an acid wash and pressure spray.
      • Bec1208
        • Nov 2012
        • 416
        #528
        Gudday Bruce
        Actually, I used a terra cotta coloring at the lowest recommended amount (4 oz to 50 lbs cement mix. I doubt I could match color as a rub on without a lot of experimentation. Bruce
          • 2848
          #529
          Gudday
          So you have some left. And if you haven't thrown out any off cuts of firebrick experiment away and just see what happens. If the colour is different it will be a different tint (to white shade) or tone (to dark shades) but it should compliment the dome colour you already have.
          4 oz to 50 lbs sounds pretty strong stuff to me . Wear some rubber gloves for sure
          • brickie in oz
            • 3445
            #530
            Gudday Bruce
            [ATTACH]38047[/ATTACH]
            Heres a bit of a line drawing of your oven to print out and draw on, colour in,
            and play with as you which.....
            regards Dave
            Youll have to email some crayons Dave, not much good with out crayons.....
            Of course the easiest way to see different colours is to use photo editing software, like Paint.net which is totally free, there are others out there too.
              • 2848
              #531
              Gudday Bruce
              Just got my oven flashed up to full temps last night. I've kept the fires low till now to dry the oven out.
              This a strawberry n cream pizza made with strawberries and Brie cheese with a bit of butter and brown sugar. It's not bad and got the child brides approval but still needs a bit of a tweek. I might soak the strawberries next time and get rid of the butter.
              I'm still taken with your fig and blue cheese pizza and would love the recipe .
              I'm just about to open the oven up now for a bit of roast pork. Oven temps down to 190 C (if I can believe the gauge it was stuck at 40 C before I used it) I plan to flash up a quick fire enough to get the cracking on the roast. I then cover the roast with foil, beer in the bottom of the dish and close up the oven. Temps should drop back down quickly I hope and give me a tender roast.
              • Bec1208
                • Nov 2012
                • 416
                #532
                Gudday Bruce
                [ATTACH]38123[/ATTACH]
                You might try a balsamic vinegar reduction drizzle with the strawberries. When I did the fig pizza, it was just some mozzarella and blue cheese with the sliced figs on top. I drizzled a little balsamic on top after it came out of the oven.
                I redid the oven door so the door front does not make direct contact with the pan. I haven't been able to try it out and likely won't have a chance until I get back from my road trip. I did make some rellenos to get in the mood for the trip. I stuffed ancho peppers with refried beans and cheddar cheese with a chipotle tomato sauce.
                • rsandler
                  • Apr 2012
                  • 363
                  #533
                  Another good strawberry variation: strawberries and chocolate. Just the strawberries alone on the pizza while it bakes, then sprinkle all over with finely chopped chocolate (chocolate chips, usually) as soon as it comes out of the oven. Then dust with powdered sugar for the looks. For bonus points, try adding finely chopped chocolate to the dough for the crust. I added chocolate equal to ~15% of the flour weight, and that came out about right.
                  • Bec1208
                    • Nov 2012
                    • 416
                    #534
                    Chocolate and strawberries, sounds great.
                      • 2848
                      #535
                      Gudday Champion
                      I haven't heard from you in a while and I was wondering how things have been
                      • Bec1208
                        • Nov 2012
                        • 416
                        #536
                        Dave, sorry to have dropped out for awhile. Had a great trip to Santa Fe. Got home about a month ago and was pretty wore out. I think a combination of the trip and having pushed my limits for several months during the build. I have been firing the oven for pizza weekly and have enough retained heat for an additional four days of cooking.
                        I'm in Orlando, FL this week in part for the Food and Wine Festival. Here are some of the events we are signed up for. The highlight is the Party of the Senses.
                        Friday, October 11, 2013
                        ? F&W France - Regional Lunches - Monsieur Paul ? 12:00 PM
                        ? Wine & Beverage Seminars ? 4:00 PM
                        ? F&W 3D Disneys Dessert Discovery - Sweet Seats ? 7:45 PM
                        Saturday, October 12, 2013
                        ? F&W Marketplace VIP Access Chef Tour ? 9:00 AM
                        ? F&W Party for the Senses - Wine View Lounge ? 7:15 PM
                        Dave, thanks for your support and continued interest. Bruce
                          • 2848
                          #537
                          Gudday Bruce
                          Good to here you took some time off after the build, it was a bit full on so you deserved a good break.
                          You're really are getting into the food thing. I'm wishing I had the time myself to do some off those things. You know of course I expect to see some of those recipes
                          Anyway off to bed
                          Great to here from you
                          Regards davr
                          • Bec1208
                            • Nov 2012
                            • 416
                            #538
                            Hi Dave,
                            Sorry to have dropped out again. Had a great time in Orlando and have been firing the oven at least once a week which gives me about four days of cooking using residual heat. Baked up seven pizzas Saturday for the FSU vs Miami game. Baked off two loafs of bread today. Still have lots of room for improvement but am still happy with results. Still hard to believe I actually built the oven, goes to show anyone can do it with the help of this forum. Thanks again for all your help and encouragement.
                              • 2848
                              #539
                              Gudday Bruce
                              Now that bread looks pretty damn good and that's one thing you don't need to be encouraged to do and that is cook like you do.
                              Buddy it's been my pleasure to have been able to help you in any way to achieving the oven that you wanted. I've really enjoyed being part of your oven building. Thanks
                                • 2848
                                #540
                                Gudday Bruce
                                We're coming up summer and have already had our first storms. I've been pottering along and have built a storm door to stop the rain beating in on those hearth bricks
                                This is MK 1 just a ply prototype but it seems to be working an we had 2 small storms test it out
