View Post
36" build in Tallahassee - AKA Bruce's Folly
Re: 36" build in Tallahassee - AKA Bruce's Folly
Thanks brickie, sounded too easy, any ideas to throw into the pot? Bruce
Im at a loss as to why its called a rigidizer?Originally posted by Bec1208 View PostWould a Ceramic Fiber Rigidizer such as linked below help?
I used some on the inside of my gas forge and the fibres didnt real change much at all apart from going blue and wet.
One more idea to toss out, how about using a castable to seal gaps?
Rutland 12.5 lbs Tub Castable Cement - Mix With Water (Fire Clay) 2200 degree: Amazon.com: Industrial & Scientific
Thanks everyone for jumping in. For anyone trying to learn from this, I assume that had I anticipated the problem I could have custom cut the length of the bricks as I worked my way up.
Sounds like consensus is forming on using a metal facing. Is there a hi-temp chalk or adhesive you would recommend to seal the edges? Would a Ceramic Fiber Rigidizer such as linked below help?
Thanks again, Bruce
Gudday guys
Well this is working well ! Team problem solving seems a more friendly and productive process. I'm sure the sniping will not stop,its a forum, but treated with indifference that such comments deserve it won't make a difference
That would work. He could also put a couple stainless tapcons through the metal into the entry arch brick somewhere to hold it. The stainless ones are a bit hard to come by, but they will hold in firebrick if you don't torque 'em in to hard.
Yes...that's it. A little tricky, but at least it will hold up and do the job. I think it will be easier for Bruce too, since it can be fabricated on the bench, checked for fit and adjusted, whereas unit masonry has to be built in situ.
Thinking about it some more, if one of the bends faced the oven arch, and another bend faced the back of the outer arch, that would add good tension to the plate.Last edited by stonecutter; 07-18-2013, 12:25 PM.
I had to re-read what you suggested. I get what you are saying now. Piece of flat steel bent like angle iron, slide it into the back of the gap so that the hidden leg is against the dome, and the exposed leg covers the insulation.Originally posted by stonecutter View PostI'm thinking that he should be able to slide the panel from the inside with no trouble.
The problem with using masory in that small area is there is nowhere to tie in....there's going to be running joints.
If I get what you're suggesting, Bruce could make it long enough to go all the way around the arch - make some cuts in the back so that he can make it conform to the arch and let the tension hold it in.
I agree with you Stonecutter. But, I think that once the two faces are closed up to the proper gap size, (filled with the insulation, and sealed)they will help to hold the brick fragments in place should the mortar fail. Like you, I also think that Bruce could "slide the panel from the inside with no trouble"...... later, if needed
just say'nLast edited by Gulf; 07-18-2013, 11:30 AM.
Your assessment is for sure better than mine on this one, I can't really tell from the pics. Just seems like something to figure out before it's all covered up with concrete and stucco.Originally posted by stonecutter View PostDJ, the insulation is showing because the oven arch and the outer arch spring from different points. The outer arch springs from the floor lever while the oven arch springs 8" above it. No avoiding what happened here, unless he tore the oven arch down and laid the lower part as stretchers instead of headers.
Tough part with a metal cover would be getting it to fit right. Seems like some combo of brick + mortar would be more forgiving, but I take your point about the two arches having different shapes.
Bruce,
It looks to me like you could add brick laterally to make the face of your inner arch wider. That would close up the gap narrow enough to seal the fibers with a food safe gasket sealer putty. I don't remember what it is called. I think Russell and a few others used it on their heat breaks.
DJ, the insulation is showing because the oven arch and the outer arch spring from different points. The outer arch springs from the floor lever while the oven arch springs 8" above it. No avoiding what happened here, unless he tore the oven arch down and laid the lower part as stretchers instead of headers.Originally posted by deejayoh View Post
If you are using it for a heat break, then it seems a bit wide and the insulation seems too directly exposed
If it was me, I would make a small sheet metal panel (SS or Aluminum), put a 90* or little less bend on the side touching the oven arch for friction, other side of the panel would slide behind your outer arch...covering your insulation. A parge of any type of material will fail.
Thanks, what about using vermiculite or perlite concrete to fill per Dave's suggestion?Originally posted by deejayoh View PostPersonally, I would'nt go any further until you address the insulation showing at the back of the entry arch. You don't want those nasty fibers getting anywhere near anything you are going to eat.
You could peel back the insulation around the entry arch where it is showing, and apply some mortar from the outside of the oven to fill that gap. Give it a good coating so that the mortar has a "T" shape fill in the gap, with the wide part on the outside - and the bottom leg protrudes through the gap. Then cut off the snots on the inside. If you try to fill it from the inside, I fear it is just going to fall out when you fire the oven as the mortar shrinks and has nothing to stick to.
