Support for brick work?
  • michaelweiss
    • Sep 2013
    • 3
    There is a picture on the 13th page of the 55 pages of pictures in the "residential" set of pictures from Lincolnshire, UK. I wanted to know if there needs to be concrete block behind the brick hearth stand(where the wood is stored)?
    Thanks for a reply.
    Mike
  • texman
    • Nov 2009
    • 724
    Re: Support for brick work?
    can you copy/past the pic so we can see which one you are referring to?
    Laziness...
    Texman Kitchen
    • michaelweiss
      • Sep 2013
      • 3
      I plan on building the stand and oven, not the flanking work stations. Does the stand need to have cinder block support under the brick or not?
      • thickstrings
        • Aug 2012
        • 138
        Pizza Oven Photo Lincolnshire, UK I would say yes....can't say for sure...
        • Les
          • Sep 2005
          • 2945
          A little confused here. If you are building the stand, what are you planning on if it's not block? Are you building it out of iron?
          • texman
            • Nov 2009
            • 724
            if i understand the ?- properly laid brick will support the stand, no need for cinder block underneath. Most builders use the cinder block because it is easy to set and then add a brick veneer or stucco for appearance. But, a stand made of brick is fine if done correctly. Reach out to the brickies on the site. Ask Al - brickie in Oz.
            Tex
            Texman Kitchen
