Hi everyone
I have finally started a build. When I mean started, it really is only started as I have just started digging the hole for the concrete slab to build the base on.
I'm also trying to finalise my design and would like some advice on the following:
(a) I'm planning on building the base out of 16" x 8" grey blocks concrete filled as per the pompeii oven plans. To support the base I was going to put some fibro sheeting supported by a couple of spans of RHS which is keyed into concrete cored blocks. On top of this will go a cement slab with some calcium silicate board on top. Do I need the concrete slab for structural support or assuming the RHS is close enough together, should I be able to get away with putting the calcium silicate straight on top of that? Also, was planning on using the following for the hearth -->
. Is this going to be thick enough at 50mm to give me enough thermal mass or should I put something underneath it like a layer of 50mm pavers? Also, does anybody know where I can get calcium silicate in Brisbane (Queensland Australia, not California)
(b) the oven will be a barrel vault. What do I need to do about buttressing the walls in order to withstand the outward force from the arch? I could concrete or refractory mortar them, however this will add significant thermal mass resulting in it taking a long time to heat up. I will at least lay the side walls in a running bond on the flat side, however I'm definitely not a mason, therefore concerned that my craftsmanship (or lack there off) will fail me and my oven!
Any advice appreciated as I want to make sure I have the design sorted before laying a slab. I would hate to lay the slab, build the base and decide I want to change the design but can't as the base size does not accommodate it.
Mark
HTML Code:
http://www.claypave.com.au/slab/
Mark
