starting the dome, checking opening size
  • clinch
    • Nov 2013
    • 29
    Hello,
    Iam starting the dome i have been busy cutting away, these bricks are hard!. and I was just needing a little comfirmation that I am getting the opening the right size for my dome. My dimensions are..
    800mm internal dome size, 32 inch
    and I have calculated, with some help from the forna bravo plans that I should be ok with 420mm wide by 280 high, which is a 32inch oven, with an opening of 16 and3/4 inch by 11inch roughly.
    How does that sound.
    Can one of you wise gentleman assist me please.
    Regards Grant.
    • 9213
    Re: starting the dome, checking opening size
    Check the plans. The height of the door opening should be around 63% of the internal height of the oven. If it"s about an inch either taller or shorter you would not notice any difference in the way the oven fires or performs.
    • boerwarrior
      • Apr 2013
      • 454
      I am neither wise nor a gentleman - but I can try and help!
      I have a 32 inch oven. My opening is 16 inches wide and 8 1/2 inches high at the sides of the front arch and 10 inches high in the middle. It works perfectly! Pictures attached.
      My build thread is here: http://www.fornobravo.com/forum/f8/3...nia-19283.html
      Good luck!
      Neil
      • clinch
        • Nov 2013
        • 29
        thankyou, sounds like iam on the right track.
        I have another question, Iam bricking the dome at the moment, I have a large wet saw, so iam getting the cuts neat, is there a problem with it being to tight the dome?.
        Do I need to leave some expansion points?.
        Not sure on this one, when I say neat there is the odd little gap maximum 3/4mm.
        I thought about leaving a slight gap where it meets the opening arch? not sure.
        cheers grant.
        • clinch
          • Nov 2013
          • 29
          Good luck!
          Neil
          Hey checked out your photos, like your outdoor oven area, and the detailing on the door opening, looks like a big job, well done.
          grant.
