Help with wanna be oven
  • Stonewall
    • Mar 2013
    • 11
    A friend on mine just bought a house with this oven inside the house in the kitchen area. Not sure what it could be used for if anything.
    The flue is in the center of what would be the cooking area. Pictures shows flue that is stuffed with insulation to stop draft.
    Also another problem is the base for the fire is granite stone.
    Questions I have:
    Is this anyway usable? Can a door be made to cover opening and something made to block flue from heat escaping?
    Will the granite bottom take the heat from the fire?
  • stonecutter
    • Jun 2007
    • 2003
    Re: Help with wanna be oven
    Questions I have:
    Based on your photos, whoever built this has no clue how to build ovens...it is built more like a fireplace.
    To your questions.....
    1) sure you can use it, but most of your radiant heat is going to exit the flue, and I think it will take many hours of a roaring fire to get the masonry to decent cooking temp....even more so if the chamber itself is not insulated ( I'm guessing it isn't)
    2) You can make a door, but it won't help much. A damper will contain somewhat heat, but it will also constrict smoke exhaust draw and hinder draft...which will lead to heat and smoke exiting the front of the oven.
    3) The granite won't survive more than a couple thermal cycles before it cracks...that I will assure you of. It is not a suitable material for the oven floor at all. ( another clue that the mason had no idea what he was doing)
    You have another firebox at best. Don't expect much from that 'oven'.
    Old World Stone & Garden
    John Ruskin
    • wotavidone
      • May 2011
      • 800
      Can't imagine it even making a good fireplace.
      I researched Rumford fireplaces after seeing many references to them on the forum, and if one accepts that a Rumford fireplace is a good fireplace, then this thing is about as far removed as you can get from "good".
      • GianniFocaccia
        • Jun 2009
        • 1645
        Why not block up the flue (or put a low ceiling in it) and heat the chamber with an electric spiral hot plate? it might take a while, but you would have the perfect chamber to keep turkeys, roasts, or rolls warm...
        • stonecutter
          • Jun 2007
          • 2003
          I build Rumfords, it is a better than good design, I can assure you. This thing is as far from a Rumford box as a 55 gallon drum, let alone a good oven.
          John Ruskin
          • wotavidone
            • May 2011
            • 800
            Yeah it's terrible, isn't it?
            My buddy wants to build one of those Argentine parrilla things to complement his oven.
            I'm thinking he ought to build a Rumford fireplace, I can't imagine a better design for reflecting heat out into his outdoor area.
            They certainly make a great deal of sense, as far as I can see. I've never seen one in the flesh but they just look right.
            • wotavidone
              • May 2011
              • 800
              P.S. I sometimes see refernces to a damper above the throat. Is this only there to prevent cold air falling down the chimney into the room when the fire isn't going?
              If so, it'd be unnecessary in an outdoor setting wouldn't it?
              • GianniFocaccia
                • Jun 2009
                • 1645
                I seem to recall reading somewhere here that Rumford fireplaces do not work outside. Ever heard of this Stonecutter?
                • stonecutter
                  • Jun 2007
                  • 2003
                  Do not work? Yes and no, I feel that most outdoor fireplaces ( not gas ) struggle with draw and efficiency.
                  The design of a Rumford throat isn't effective outside as other outdoor fireplaces with a deeper box and open throat. I have built a few outdoor FP's that had a modified Rumford box, but the throat design was the major difference, as draw characteristics are completely different outside. Most of the ones had a very slight shelf or none at all, not like a Rumford at all.
                  John Ruskin
                  • stonecutter
                    • Jun 2007
                    • 2003
                    A damper is not optional with indoor fireplaces.
                    I have put them in on the first few outdoor Fp's the past, but they are pretty useless, especially in areas with a bad downdraft problem...like being at the bottom of a hill surrounded by trees.
                    John Ruskin
